Theme caused malfunction with Note8
MisterBear
I installed a theme from Samsung Themes. It was called Optical Blue and it was animated. Now, the edge lighting randomly flashes red. I have changed themes several times and rebooted as well.
I don't even like the edge lighting. I thought I had it disabled.
I have Developer Options enabled. All animations are turned off.
Note8 running 8.0.
What's next for me to attempt as a fix?
Long shot but can you boot into recovery and clear the cache from there?
I assume you've uninstalled the app normally with clearing the cache and data first.
