There's no Solutions yet?????
namlee78
Member
Good evening all,
I have been researching "remove second google account" on my incredible and nothing but factory format. Is this only way to delete/remove second google account from my phone?
I'm using google Apps Standard Edition which is using my own domain name.
Everything is ok till I add second gmail account like xxxx@gmail.com
I would like to remove it but, it said "This accont is required by some applicatins. you can only delete it by resetting the phone to factory defaults...blablabla....."
Try kill all programs and try to remove it but, it didn't work. Call verizon and spoke with them two hours...they transfer me here and there and no solution but do a factory format.
Somebody can help me out???????
Have you tried clearing the cache on the google apps app in application list? that should delete all your google accounts so you'll have to re-enter the account you want back afterwards though.
I thought multiple accounts was a feature of 2.1+... with 1.5 it was definitely limited to 1 account.
I did try everything...
If my standard google account is count as gmail, I set up two accounts and it was working fine. just want to delete one though.
