Root Think i bricked
tried to return to stock droid2 a955 flashed the sbf file using rdslite and when it finished it would only say on the boot loader this:
bootloader
d2.37
err:a,70,70,00,1f
new_map blank
service req'd
battery ok
ok to program
connect usb
data cable
anyone give me a hand?
Its hard bricked. There is no way to SBF or anything to fix it yet. I had to send my girlfriends back to Verizon for a replacement.
I had the same problem trying to upgrade the gf's phone. Spent about 3 hours trying everything to resolve it and finally got it taken care of. You need the RSD 4.7 Lite with the patch ini. You install the RSD 4.7, then copy the patch ini into that directory...
I think I used this site:
Kimete.com - DarkOnion's House of Pain
I actually had to try to run it twice with the patch.ini installed...
