Time Calculated by Distance and Speed
Ametz
I have tried to find a simple calculator for Time Calculated by Distance and Speed on the market but i cant find any..
Speed: <Enter value> <SET SCALE> (mph, km)
Distance: <Enter value> <SET SCALE> (km, miles, metres etc)
[ Calculate Time button ]
Sure i find ALOT of GPS or more advanced calculators i cant make head and tails of.
Also i found and tested a few converters, but i can't seem to add more then 1 value to convert to another value..
This is what i seek:
1. Time Calculated by Distance and Speed
Time, Speed and Distance Calculator
2. Time Calculator
Speed Distance Time Calculators
3. Time from Distance and Speed
http://homepages.ihug.co.nz/~gazzanic/distance.html
Ok i found what i was searching for now:
RySaRuningCalculator
https://market.android.com/details?id=rysa.runcalc&feature=search_result
Not to be snarky (ok maybe it is)....but is it really that difficult to use the divide function of the calculator app.
I agree. The calculator should suffice OP needs. One can't be so lazy until they want a dedicated app to do such calculation? Imagine another OP want the Fahrenheit to Celsius conversion, mile to kilometer, feet to metre etc whatever conversion.
Ahh but I get the point behind a convertor app. Other forms of conversion require a conversion formula to remember such as for Fahreneheit to Celsius you have remember the formula
Search for flight computers or E6B. I haven't looked myself, but I bet you'll find something that suits your needs.
