Yes the PROCESS MANAGER (name of app) I use allows you to choose which apps. You want to keep running in the background...... I have not tried it for timescape though because I am not a fan of timesape... I like the concept just think it could use a little work..... maybe with an UPDATE?????
Just found out if i use mine to cllose timescape it causes this issue. Just as it makes the alarm not work
Can't get timescape to update for the life of me. Everything is stuck from two days ago despite several incoming calls. And I'm not running any task manager application either.
I tried the remove/reinstall widget and that didn't do anything either.
Also what the heck is the difference of customize splines and customize tiles in the timescape setup?
Also is the a way to filter what email accounts you can have showing in timescape?
The program seems like a good idea implemented badly. Time to remove it I guess.
Any other program out there that displays similar info even just for calls and texts?
