Tired of being asked to connect to wifi? Click here
Ronk2010
Wanted to share this tip I just came across. If you are tired of your S3 asking if you want to connect to WiFi, open your phone dialer and enter *#6335623#
A menu will open with options to turn that feature off.
Works on VZW. Don't know about other carriers.
One more time not having separate forums for different versions raises its ugly head again :(
I see your on VZW................this does not seem to work on my AT&T S3. Oh well.........."these types of issues will settle down in a couple of months". New phones will be out. Just hurts this site in my opinion at least.
I don't see the problem, his tip might work on several different phones, if it was in a VZW forum the rest of us who have no reason to visit that forum would miss out.
Completely agree. Just because it doesn't work on AT&T, doesn't mean it won't work for every other phone.
I'm getting a bit sick of this mentality where everyone thinks if it doesn't work for them, it must only work on the phone version the OP had.
I must be in the minority here.... I personally like the reminder.
Why?
I would always prefer to use WIFI, when available/secure.
1) Better throughput
2) Better battery life
3) Lower data usage (although a moot point in my case since I have unlimited)
I like it too. Serves a s a notification that something has gone wrong and my WiFi is on when it should be off.
I posted the tip to show people that they have the option. Like every other tip on here, you don't have to use it if you don't want to. I don't have any interest in half of the posts on here, but I like knowing that I have the option. It is unfortunate that it doesn't work for all carriers, but you never know until you try.
Or you can just uncheck "Network notification" under advanced wifi settings.
Both good tips/solutions
Doesn't work on the unlocked/unbranded international version though.
@Op maybe tag your post title with [Vzw+?] or something similar? Then verizon users know it 'should' work for them and other users know it 'might' and people can feedback from there. Just a suggestion.
