i have a xperia play running 2.3 gingerbread. i used titanium backup to move my user apps to the micro sd card. i moved all the stuff on the 8gb micro sd card to a 16gb card. now none of my apps show up. help please!
If you used Titanium Backup, then you are rooted, then you should be able to restore all your apps by simply copying the SD card content from the old to the new card.
If you are not rooted, then you simply moved the apps to SD card and swapped it with a new one. Again, simply copy the content of the old SD card to the new one.
