Titanium backup not reading SD card backups
archz2
I recently installed a custom ROM on my phone. I backed up earlier everything using titanium backup. Now, the problem is, the new ROM leaves 66 mb on the internal storage. I have everyting backed up upto 1GB on a titanium backup folder on my SD card. Strangely, titanium backup is recognizing only the backup files present on the internal storage and not the SD card. What should I do to make this app recognize the backups from SD card?
Have you tried looking in Titanium's settings and set the "Backup folder location" by hand rather than relying on it detecting it?
IIRC I had some issues with Titanium Backup not always recognizing backups due in part to changes to file system handling in different versions of Android. There are apps out there that can fix those issues, though I don't know whether that would help with your specific case.
