Titanium Backup Pro (What is Hypershell FAST!)
Found this excerpt from a blog that reviewed Titanium back up pro.
Click Restore all Missing apps with Data and its done.
Here, if you have the pro key to the, also available in the play store, it enables HyperShell. What it does is, when you're restoring apps and HyperShell is enabled you can just sit back and titanium backup will do all the restore but if its not enabled then you will have to click install and done for each app, which is quite handy. Thank God for HyperShell.
Here's the source.
Atishay's: Review- Titanium Backup
