titanium backup pro
96Klassic
so i downloaded this app from the app store and is shows the check mark on my status bar saying it was installed properly but it doesn't show up in my app list at all but i can see it when i go to settings and manage apps...
how do i fix this issue...
Have you tried restarting your phone? I've not heard of this particular problem before, but a simple restart may fix it.
I believe that you have to have your phone rooted for it to work. I could be wrong because I have not yet rooted my phone.
my vibrant is rooted...[/QUOTE=96Klassic;1768870]
I realize you said your phone is rooted. Do you have the Superuser app in your app list? This automatically happens after you root (did for me). TB won't be able to be used if you don't have Superuser, nor would BusyBox - which is also part of TB by my understanding. Do you also have BusyBox in your app list? They work in tandem.
Did you download the Pro version that's a paid app? If so, it's only a key and you have to download & install the regular free version afterwards. It will then find the key and install itself as the Pro version.
