This free application works as a widget that you press to disable the screen timeout; when you press it again, it goes back to the screen timeout time that you had most previously set. This is great because it prevents you from having to go all of the way into the display settings if you want to keep the screen from timing out in order to view something (such as a webpage that you're referencing). The icon isn't the most attractive widget, but it gets the job done. I have been using this for almost three months and have never had any problems with this application.
