Help Touch screen problem
I've been trying some game require multitouch like NOVA or Sandstom on my MS 2 and I found out that there would be a problem. I tested with my friend's MS 2 too and mine is not the only one has that problem. I download the multitouch test app and this is the result:
- First use your 1st finger touch the screen to create 1st touch point, then use your 2nd finger to touch the screen to create 2nd touch point.
- Leave your 1st finger out of the screen, the 1st point disappear, there would be 2nd touch point left at your 2nd finger position.
- Use your 1sr finger to touch the screen again, now, it creates 2nd touch point at my 1st finger when the 2nd touch point at my 2nd finger becomes the 1st touch point.
=> 2 touch points have changed there position to each other's after you leave your finger and retouch it. I tested with the milestone 1, when you touch the screen again using your 1st finger, the 2nd point still stays at your 2nd finger position and the 1st finger creates the 1st point.
Does anyone have any idea ?
My touch will not respond in the middle, is there any thing i can do?
Have you tried doing a hard reset? If the problem is software related, doing a hard reset or even better flashing a non-service SBF will help things.
Be aware, that doing a hard reset/ flashing a non-service SBF will erase all settings and data on your phone, but not on the SD card.
