2prevail
Well, anyone who has done the slightest of work on their phone but is still on a stock rom should see that annoying triangle under samsung when you first boot. Well if your feeling some type of way about it there is an app called triangle away that resets your flash counter, ultimately removing the triangle. It is functional on some phones outside of the supported list but a hard brick is likely if it doesnt work. This is my only phone as of right now and i dont want to risk a hard brick so if anyone would like to try it and tell me if it works much thanks to you!
