Trouble transfering files from phone intern and external to pc
TegraDroid
Been getting this problem lately where ill transfer files such as pictures and music from phone to pc and it freezes during transfer. and another annoying feature is the constant pop up to allow to connect to my computer. Im on LG Stylo Boost mobile running 6.0 mm. After sending in my phone for repair to camera it came back with 6.0 cool no big deal but after inserting my sd ccard it corrupted it and killed it forcing me to replace it with a new one this time class 4 instead of class 10. i did not format new one it went in without issue and is a 32 gb same as previous one. my question is ....is there a way to disable the the pop up to allow to connect every time connected to pc? and is anyone else having transfer issues?
If it's constantly asking you to allow PC access to your files while it's connected to your PC, it could be that the connection itself is faulty, maybe the USB cable or your phone's port.
sorry been a while we moved into a new house..but i bought 3 new cords and same thing i figure its the usb port but sometimes it works great other times a whammy
Sounds like it is the USB port but I'll ask anyways>
Since your phone is on MM, did you format the card as internal (adoptable) or are you using it as external (portable)?
We have the same issue with out sprint lg g stylo / MM. All was good until the MM upgrade. No matter what PC, lappy etc or cord we use it happens - real PITA!
