Oh okTalking and discussing torrents and the use of torrents(piracy) is against Android Forums TOS rules.
I wasn't aware torrents were a topic banned here in Android Forums, please post the FAQ or TOS stating this?Talking and discussing torrents and the use of torrents(piracy) is against Android Forums TOS rules.
There are no default numbers to guide you, it's mostly just experimenting with the optimal numbers that suit your situation. Your ISP (WiFi) or carrier (cellular) play a part as far as your bandwidth speed, along with if you're doing a lot of other things (watching Netflix) along with torrenting.If you bump up the connection numbers significantly you'll be using more bandwidth, which may or may not even be adding more seeds, but at a cost to other apps that may be affected by reduced connectivity. Maybe start with max open connections at 130 and max incoming at 80 and then adjust up or down accordingly. Also, a lot of providers are not just blocking torrents but all peer-to-peer functions so if your torrent app is using a port in the 6800 to 7000 range so try changing its default port to something maybe 9000 to 10000.Can anyone tell me the the max open connections and max incoming connections should be set to for best performance
