So I have used TuneIn radio for ever with never any issues. Now all of the sudden, when I open the app, it just randomly closes (well more like sudden just back out of it. if audio plays, it still plays then the only way to get it to stop is force closing it) few seconds later.
Heres some error I see in System Tuner log:
I have reinstalled, cleared data, rebooted, all of that and nothing fixes it.
The only thing I did was dirty flash from CM10.1 beta4 to the most recent stable build of CM10.1
Have not had any other apps have this issue. This is an app I use every day, so was seeing if I can get some input with out wiping everything and reflashing just for this one app..
What would make it "back out" all on its own just a matter of seconds after opening?
Launching TuneIn Radio free version
dlopen("/system/lib/libtunein.oem.so") failed: Cannot load library: load_library(linker.cpp:771): library "/system/lib/libtunein.oem.so" not found
error opening trace file: No such file or directory (2)
