If you are an avid iTunes user like myself, you know what a hassle it can be getting your iTunes playlist neatly into folders on your Android device. Well, this application can solve you problem, any time you connect via WiFi to your local network, it will sync the playlist you have selected, to you device. No need to find that cable to mount your sd card. This does it all for you, without wires. This application is a must have for those who listen to their music on the go!
