Turn on GPS when leaving home
tennvol
I'm looking for a app that will turn on the GPS when I leave a location, and will turn it off when I arrive at a location.
Example: I leave the house and the GPS is turned on, I arrive back home and the GPS is turned off.
What do you want to use to trigger your phone that you are home?
_bill
I believe if you use Locale + GPS Plugin this should be pretty easy. Though I think locale has some issue with GPS right now on the droid, should be fixed shortly though hopefully.
