presence06
Member
TweetDeck for Android is by far the best Twitter client for Android. Totally put the Official Twitter for Android to shame. Sign up at TweetDeck and get started using the Beta. It's a solid app. You can add Twitter, Facebook, FourSquare and Buzz accounts and sync them all in one timeline or, different "columns". Set how often it's updated, how it notifies you and even change the notification sound.
Give it a try, here's the Change log for .0.9.9 from DroidDog.com
-Fixes for Facebook feeds
-Fixes for issues where notifications do not display
-Fixes for various crashes
-Fixes for problem with missing tweets
-Fixes for problems with operation & display of widgets
-Performance fixes
-Improved handling of Facebook
-Performance fixes
