I would like to integrate the battery icon set discussed here:
[Themes] Battery icons (inc) Works with multiple roms - xda-developers
...which apparently exist for Virtuous 3.1
would also like to integrate the 6-bar signal strength meter discussed here:
6 signal Bars on Virtuous? - xda-developers
I'm told that there are no changes to "services.jar" between 3.1 and 3.2 (in connection with the second change) but both apparently make reference to the "framework." I'm not a programmer; don't know what any of that means.
Bottom line, can these two changes which apparently work in Virtuous 3.1 be made in Virtuous 3.2? (And will they "undo" any other mods, such as the rotary lock screen I installed?)
Informed opinions always highly valued here.
Update: Both mods work on 3.2; running them now.
