Twrp for lg g stylo MM
Im on Metro. When i upgraded to Mm, i used the tmo kdz to downgrade then upgrade to MM. I use the same TWRP that weve been using. I will be attempting to downgrade back to stock LL, upgrading to stockMM metro version, and then want to see if i can reroot and reiinstall twrp. Ill let you know how it goes.
Jack, when you had the Tmobile MM on your Metro Stylo, did you have Advanced Text Messaging?
@tube517 Yes i have advanced messaging in the message settings .
I just installed the MetroPCS MM update and tried to install twrp and couldn't either. Same one we've been using. Also tried to fastboot oem unlock and no go...command window hung saying waiting for device. Hmmmmmm any ideas?
I got it last night after 6 hours of trying. It was a mistake on my part. I didn't have the adb drivers loaded properly. i reinstalled them to my c:drive and ran again and it about 2 mins I was good to go. Thank you man. I appreciate it. IM UNLOCKED!!!!!
