Hook
Ever since DU... ;-)
Once again, I have been occupied heavily elsewhere for about a week and I may have missed something about this in the many Lollipop threads. However, this threw me for a while until I got it researched, so I thought I would post this for fellow noobs.
When you create a Nandroid Backup in Lollipop using TWRP 2.8.1.0, you will see it on the restore list, but when you reboot, neither Root Explorer nor Windows Explorer sees a TWRP folder in Internal Storage. This was concerning since I want these files on internal memory and I want to be able to copy them to my PC or delete them when they are OBE.
Turns out that they are stored at /data/media/0/TWRP. Which appears to be another symlink to the Internal Storage, but apparently one that has peculiar properties. You can see this folder in Root Explorer as if it were in phone memory, but you can't see it if you are connected to a Windows computer with Windows Explorer.
The magic trick turns out to be that you have to boot into TWRP and then plug the Nexus 5 into your Windows computer, at which point the MTP connection with TWRP will make that folder accessible in Windows Explorer.
I'm sure somewhere around the webs the TWRP people have explained it, but I couldn't find it other than references to TWRP having MTP mounting capabilities (which was the clue that sent me in the right direction). Once you know how it works, it's fine, but it wasn't something that was obvious to me.
Hope this saves some folks some time. Sorry if this is something I should have known and everyone is rolling their eyes at me. ;-)
