lotcav123
I need help with android box TX3 pro . It won`t update to new version, it says something about server error. Current version is 6.0. Through google play it won`t install any program, it says that it isn`t supported. I can install program only if I downloaded it on my computer and transfer it on usb stick to android.
I found some firmware:
https://www.entertainmentbox.com/la...ndroid-marshmallow-6-0-firmware-download/amp/
version of this firmware is 20160816
On my andorid I found that it has Android security patch level - June 1, 2016 and Build version is 20160707
Should I update this to this version? I am afraid that it can maybe brick my andorid box. I sent mail to TX 3 pro manufacturer, they haven`t respond anything.
