THIS ROM IS NOT MINE IT IS MADE BY BLACKDROID!! All the links should be correct and the donate links should all be right for theblackdroid.This rom is literally flawless it is smoking fast and everything works as it should!If you have any questions go to irc channel #blackdroidmod or you can just hit irc at www.blackdroidmod.com File NameUltimate Droid Froyo eXteme (RC1) by the blackdroid SubmittedToday, 03:31 PMLast UpdatedToday, 03:38 PMFile Size74.38MB (Estimated Download Times)Views0Downloads7If you like my work and would like to keep the site and development funded donations are appreciated
Update.zip Installation Info & Instructions: (install over any working froyo - NO WIPE NECESSARY)
- Be sure to have signed into your Google account before installing
- Update (if available) all of your apps before installing
- Download update.zip
- Rename to update.zip if not already done
- Place update.zip on the root of sdcard
- Reboot into recovery
- Install
- Allow update.zip installation
- Install /sdcard/update.zip (deprecated)
- Change all animations to fast (Ultimate Droid Control Center)
- Remove and install extra apps (Ultimate Droid Control Center)
- Enjoy!
Overclocking Kernels: (Update.zip format - Installation instructions Above)
(Credit to P3Droid)
- 800mhz
- 900mhz
- 1000mhz
- 1100mhz
- 1250mhz
Chevy's Froyo Kernels Link
Ultimate Droid Froyo eXtreme (RC1) Changelog: (All changes that have been made from froyo beta are in bold and red)
- FRF57 base (credit to Google)
- Fully Deodexed System (credit to Google)
- Fully Zipaligned System (credit to blackdroid)
- All Images Optimized (Credit to blackdroid)
- Block all adds in apps and browser by default (Credit to blackdroid)
- Less cpu intensive live wallpapers (idea from Chevy)
- Shortened ring delay (Credit to blackdroid)
- Increased wifi scan intervals (saves battery life - Credit to blackdroid)
- Camera Sounds disabled by default (credit to blackdroid)
- Version Information In Settings -> About Phone (credit to blackdroid)
- All commands in busybox and toolbox have been symlinked (credit to blackdroid)
- Added Wireless Tethereing App (credit to android project)
- Added Adobe Flash (drops on sdcard for easy installation with a file manager such as Astro - Credit to blackdroid)
- 3 Themes Available (Smoked, Nextheme, and Droptheme - themed facebook, pandora, and twitter included - all fully optimized - Links Below)
Added the Ultimate Droid Control Center which gives you: (Screenshots Below - No Custom Scripts Necessary) (Credit to blackdroid - made from source)
Quick Commands ("What Makes Scripts Obsolete" - The ability to use any command without the need of a terminal)
* Apps2sd Hack (Gives you the ability to install any app to your sdcard)
* God Mode (Gives you the abiltiy to view or edit any file with any file manager)
* Reboot
* Reboot Recovery (Reboots into recovery mode)
* Power Off (Powers off the phone)
* Install2system (installs apps from /sdcard/system to /system/apps)
* mount system read/write (mounts the system read/write)
* mount system readOnly (mounts the system read only)
* free 50mb (keeps 50mb of system memory free)
* free 75mb (keeps 75mb of system memory free)
* free 100mb (keeps 100mb of system memory free)
* Sound On (disables camera and video recorder sounds)
* Sound Off (enables camera and video recorder sounds)
* Show All Ads (shows all adds in browser and applications)
* Block All Ads (disables all adds in browser and applications)
* Disable Boot Animation (disables the boot animation)
* Enable Boot Animation (re-enables the boot animation)
* Change speed off all animations
Built-In Applications (Allows all included applications and some system applications to be easily uninstalled and reinstalled):
-Extra Apps
* Amazon Mp3 Music Store (credit to Google)
* Chrome to Phone (credit to Google)
* Facebook (Included as an extra themed app in UD Themes - Does not come stock - Credit to blackdroid)
* Native Instant Messenger (Credit to credit to Zappletoo)
* Old Media Dock (Included 2.0 Alarm Clock App - Credit to blackdroid)
* Pandora (Included as an extra themed app in UD Themes - Does not come stock - Credit to blackdroid)
* Native Usable Quick Office (Credit to Pete)
* Usable Sound Recorder (From G1)
* Twitter (Included as an extra themed app in UD Themes - Does not come stock - Credit to blackdroid)
* Wireless Tethering App (credit to the android project)
-System Apps
* Calculator
* Email App
* Launcher
* Mms App
* Native Browser
* News and Weather App
Device Info:
- Battery History
- Battery Information
- Usage Statistics
- Memory Usage (To see how much storage you have, and how much has been used up in system, data, cache, and your sdcard)
Tools & Utilites:
- Busybox
- Flash Image
- Dropbear
- Bash Shell
- Zipalign
- Toolbox
- VPN
- Install
- Enjoy!
(Credit to P3Droid)
- 800mhz
- 900mhz
- 1000mhz
- 1100mhz
- 1250mhz
* Reboot
-Extra Apps
-System Apps
* Calculator
* Email App
* Launcher
* Mms App
* Native Browser
Device Info:
- Battery History
- Usage Statistics
Tools & Utilites:
- Busybox
- Flash Image
- Dropbear
- Bash Shell
- Zipalign
- Toolbox
- VPN
