BoiledFunn
SOLVED
I flashed CM11, enabled CM Recovery, then updated to Cm12.1 (latest nightly) through the CM Updater. I had tried this before without using the CM recovery with no luck, either the update would fail or my original issue would persist.
Hurray! finally my personal device is fully operational on CM12 and the devices I had to sell are good to go.
Hi there helpful people!
I am working on a Sprint S5 (SM-900p) which I have been using for months while ignoring this issue.
I'm running CyanogenMod 12.1, and everything works just fine, apart from my ability to receive incoming calls, or hangup on outgoing calls. I can make outgoing calls, but when I try to hang up, the dialler app says hanging up, but the connection is held.
When someone else calls me, the call rings on their end, but I receive no indication on my device that any connection is being attempted.
The strange thing is that when running stock Samsung firmware I have no issues. I have tried various paths to installing CM, such as starting off on stock 4.4.4, then progressing through OTA updates to 5.0 before installing CM, thinking that might help, but no dice yet.
I've tried installing other ROM's such as the Resurrection-Remix (CM12-based), and older CM12 builds.
I've done a lot of searching and haven't found anyone else with this issue. There are plenty of reports of people not being able to hang up after calls due to a sketchy proximity sensor, but that's not the issue with me.
If anyone can help me out I'll be super stoked! I'm about to head to work but I can check back in a few hours to answer any questions people might have.
Cheers wonderful helpful people!
