hi since the latest update im unable to control the volume with the buttons on the side of my phone any ideas ? its really annoying going in to the settings all the time
thanks alex
This may be a bit of a reach, but can you check at Settings > Accessibility > Switch Access to see if it is enabled? That feature lets you use hardware buttons (like the volume buttons) to control the phone, so if it had been inadvertently activated it would disable the volume control.
