Unlinked link2sd for new sdcard and now i can't create mount script
MustangLife
So I'm a long time user of link2sd and actually link2sd plus. I've partitioned 4-5 sd cards successfully using link2sd. Mine, my gf, and my 2 roommates. I decided to buy a class 10 samsung 64 gb sd card because my 16 class 4 was tapped out on space.
I unlinked everything totally linked to link2sd. And uninstalled link2sd and link2sd plus package and installed the partitioned new sd card. fat 32 and ext4 like I've always done. But it says " mount script cannot be created. mount: Invalid argument
I don't know what to do. I used a mini tool partition like always and even tried ext 2 once to see if that did anything.
Any help is appreciated.
FYI - Link2sd worked perfect prior to the new sd card. Is there some files i need to delete before trying to creat the new mount script. Since the same phone was using link2sd before but with a different sd card
Reset Your Device, Try Partitioning With "A Parted". some Times Mini tool Does Not Work. Same Happened With Me Many Times.
You Can Also Try CWM Recovery.
I got the partition / Links2SD mystery solved, took me **hours**.
Here we go:
Using MINI TOOL (several times, across two different SDHC 64GB mini SD's, LOL! I was going batty) I finally formatted 12gb as ext4 on that app, placed back in the Redmi Note 4G Dual sim) phone of mine, and I got partial success across two different apps: Apps2SD, which intermittently would mount the partition but then never would write the script, several reboots, then once I got a stable indication that partition 2 mounted and stayed mounted, (I checked on many apps: DiskInfo, Apps2SD, Aparted, others) THEN I RE-INSTALLED Links2SD. Miraculously the ext4 partition stayed mounted and it FINALLY gave me the success of the mounting script being created.
Hell, I couldn't believe it. I thought I was hallucinating. Nearly nine hours straight, not a bite to eat.
Yeah I was obessessing a tad bit ... But I got it
