Help unlocked one plus help
PLEASE PHONE HELP. OK I want to buy a one plus in USA. I was wondering would I be able to get att service on it and would be 4g. Also would there be any other additional fee other then activation.
Yes. AT&T uses LTE 700MHz, which is compatible with the OnePlus One. Activation and taxes should be the only fees, aside from the monthly plan.
I used my OnePlus One over the summer with Straight Talk using AT&T's service and it was great. It was a lot cheaper than using AT&T directly too.
I used it on both AT&T & T-MOBILE w/100% compatibility,including 4G LTE.
The AT&T was prepaid,but,the postpaid version of both carriers shouldn't need any special "activation fees" if the account/SIM Card is currently active.
Just pop in the SIM Card & go,the phone will automatically detect which SIM Card you have & should automatically use the proper APN settings w/o any manual input/alteration.
Wait, So you can confirm that the 1+1 works on AT&T prepaid, As in their gophone plan? I'm a teen and cant afford a monthly plan, so pay as you go is my only option.
Yes.I bought a months worth of service w/either 2.5GB or 5GB of data (can't remember).
I popped in the SIM Card & the phone automatically detected it was an AT&T SIM Card.
4G LTE on AT&T blankets my area & worked flawlessly.
Thank you.
