That´s too bad. Do you know of any other code you can use? Thanks for your answer.I'm pretty sure you need another Sim card for that code to work.
So, the code is useless for Lollipop and Marshmallow? If so, do you know of any other codes that can unlock?It hasn't worked since KitKat IIRC
Sorry if I sound like a broken record, so if you don´t have another SIM card. game over?There aren't any AFAIK sorry.
Oh I see. Unless you root I guess there is no way out. Got it. Thanks for your help.There are ways with root I believe but I haven't looked into it as I got an unbranded device this time but I had to get codes from my Provider for my GS4 on lollipop. They took a while to come through as my provider had to go to Samsung. Before I did that I tried a few online unlocking sites but none could help me
