Root [UNOFFICIAL][d320n D325 ms323][KK] PAC-man ROM (28/08/2015)
M
Member1771050
Guest
PAC-ROM is built with our own tweaks and options, including picks and features from the best ROMs out there!
Why choose among ROMs, when you have All-in-One !!
* By flashing this, you automatically void your warranty! *
* If your phone breaks, blows up or runs away from you, do not cry to us! *
* Do not ask for ETAs!! *
To install, you'll need unlocked bootloader and latest TWRP recovery!
TWRP by vm03, download it here
* Download the ROM and GApps *
* Reboot to TWRP *
* Wipe data/factory reset *
* Flash the ROM and then GApps *
* Reboot your phone *
* Enjoy *
* Download the latest version *
* Reboot to TWRP *
* Flash the ROM *
* Wipe both dalvik cache and cache *
* Enjoy the latest version of PAC-ROM *
* NFC for d320n
* Other unsupported variants of L70 have their own bugs
KEY FIX FOR MS323
only if you have keys problem!
Flash this file via TWRP:
ms323 key fix
(pico or nano recommended)
* PAC-ROM Team *
* Cyanogen Team *
* AOKP Team *
* DirtyUnicorns *
* SlimRoms *
* Vanir *
* Omnirom *
* @vm03 *
* Special thanks to all our Build Bot Providers (see Contributors list for all names) *
* PAC Graphix Team - Graphics, logos and images (see Contributors list for all names) *
* And of course, thank you for your love and support! *
Source:
Device trees: https://github.com/zlaja/android_device_lge_w5/tree/pac-kk
https://github.com/zlaja/android_device_lge_msm8610-common/tree/pac-kk
Kernel: https://github.com/vm03/android_kernel_lge_msm8610/tree/cm-11.0
Proprietary: https://github.com/vm03/proprietary_vendor_lge_msm8610-common/tree/cm-11.0
PAC: https://github.com/PAC-ROM
Too late I wiped data
Now I'm looking at this awesome bootanimation, I love it. Thank you man you're really awesome (almsot as awesome as this rom :p)
I't started up, time to do the setup wizard
PS.: If it helps I'll gladly take screenshoots :)
Please do :) I'll update OP with your screenies :)
P.S.
On first boot I experienced that back and menu button suddenly stopped working, fixed that with reboot. I'm telling this if by any chance that happens to you ;)
Settings-pac settings-buttons
Can't set double tap, long tap etc :/ little disappointed....
Ok :)
Double tap is feature of stock ROM for LG. It first must be featured in cm11. When that happens, it will work in this PAC.
For the rest: This is the initial version, we will iron out the bugs eventually.
EDIT:
I just realized that you haven't said it don't work, but that it's missing :D
Well... sorry about that.
Changelog:
nightly-20141220
- Fixed init.d support
- Added missing torch app
- Superuser problem fixed
- Updated to latest nightly
- Cleanup of uneeded files
Adding the line works. As for other problems. No Button except the back button works. BTW before flashing you definitely need to completely wipe.
Also attached gpio_keys.kl from my cm11. Its a bit edited. I use sim switch as recents. Btw tried gpio keys by putting it into the ROM zip file and home button is now functioning as menu key for some reason. Only back is functioning properly and others don't work.
@XeVile Thank you for testing and reporting. I did this with having d320👎 in mind, so I based it on the version for d320, that's the most probable reason why your buttons don't work. You can enable softkeys as a temporary solution, in build.prop change qemu.hw.mainkeys=1 to qemu.hw.mainkeys=0 or just delete the whole line.
Since vm03 recently unified bases (one rom for all phones) I will do another version based on that one as soon as unified rom stabilizes (for now it sometimes reboots to black of purple screens). This way, my rom will also be one-for-all :)
Looking forward to it ;) btw did you build ROM from source?
Nope, I've stated in OP that I ported this from Motorola E :) If I had knowledge, it would be easy to do so, since we have pretty stable cm11... But I don't. Sigh...
