Root UNOFFICIAL LineageOS 15.1 for LG L70 D320 D320n D325 MS323
vm03
Android Expert
Absolutely NO WARRANTY! You can brick and destroy you device!
For advanced users only. Please, no stupid questions.
For install need unlocked bootloader and TWRP 3.2.1 (or latter) recovery.
For correct working RIL (Sim detection) and keys you need correct (for you variant of L70) bootloader (aboot.bin).
Working:
  • Display
  • touchscreen and multituch
  • Hardware 3D rendring
  • RIL - SMS, MMS, calls...
  • Mobile data
  • WiFi
  • Bluetooth
  • GPS
  • Camera - photo
  • WiFi, Bluetooth, USB tethering
  • Audio - speaker, headphone, mic, routing, voip calls, etc
  • SD card
  • Hardware video decoding and encoding
  • Sensors
  • FM radio
  • Double tap to wake
  • SmartCover
Not working:
  • Camera - video
  • NFC for D320n?
  • Rear camera for D325f8?
  • Any others for unknown for me versions and revisions.
Download
https://vasy.ru/LineageOS-15/w5/
TWRP 3.2.1
Source
Kernel,Device... https://github.com/CM-LG-MSM8226
  1. Copy zip's to SD
  2. Enter to recovery
  3. wipe data
  4. install zip from external_sd lineage-15.1.<...>.zip
  5. install zip from external_sd gapps
  6. reboot
Donate
intsalled the rom its working well with some small bugs. when will the gapps for 8.1 will be released?
Screenshot_20180121-144630.png Screenshot_20180121-144636.png Screenshot_20180121-144649.png Screenshot_20180121-144657.png
changing "ro.product.name=lineage_w5" to "ro.product.name=w5" no longer works to fix camera problems?
I do not have the device anymore.
@vm03 add the line:
"run_program("/sbin/sh", "-c", "sed -i 's:ro.product.name=.*:ro.product.name=w5:' /system/build.prop");"
Note: after the unconditionally patching installation and before the command that dismounts the partition /system, in the rom "updater-script" file.
I do not know why, at the time of compilation, the script inserts the rom name in the line "product name" when generating the "build.prop" automatically. but I know that this generates issues for free on several devices I've tested. Like the light stripes and the rear camera for D325f8
Please! Check the eighteen line in the attached file.
I hope this helps!
Grateful for the attention!
I installed the rom (without GApps, su addon, xposed etc.) and it worked pretty good, except that I couldn't add my Google Account, since i didn't install the GApps. Turns out, nothing worked after doing that. SystemUI, com.android.acore, com.android.phone and some other things started crashing and I couldn't get past the "Checking for updates..." screen. I have a D320, patched aboot.bin and TWRP 3.2.1-0.
Any Updates on this?
unofficial Gapps 8.1
[QUOTE = "ClauvanPdST, post: 7699688, member: 1804719"] mudando "ro.product.name = lineage_w5" para "ro.product.name = w5" não funciona mais para corrigir problemas de câmera?
Já não tenho o dispositivo.
In my Lg l70 D325f8 it worked yes, normal! :)
Em meu Lg l70 D325f8 funcionou sim, normal! :)
Now ... Please respect the rules of the forum.
Put everything in English and continue in this language from now on. Hehehe
Previously I was posting in both languages, but it was very tiring.
Otherwise you will take warning of moderation!
Thanks for the feedback!
Oh, okay, I'm sorry about that! :oops:
Okay, since we got no answer, I went ahead and installed the latest update.
Flashed directly from TWRP, both ROM and GAPPS (http://downloads.codefi.re/jdcteam/javelinanddart/gapps - Mind the Gapps are working perfectly for me).
Overall, great ROM, haven't found any problems yet.
EDIT1: NFC and Video on camera are not working, as listed as known bugs. Automatically, root is not available, but it is easy to root.Just flash latest SuperSU from TWRP. (http://www.supersu.com/download)
