Root UNROOT Huawei m835
yanks_35
Does anyone know if there's a way to unroot the Huawei m835 or it is not possible yet? And doing a factory restore won't work. Thanks
someone correct me if I'm wrong, but I used SuperOneClick to root my phone, I believe it has an unroot option in it, in case you ever wanted to unroot it. maybe try there?
This website may be able to help you out if you decide to use SuperOneClick
Yea I used SuperOneClick to root the Huawei m835. But i afraid that the unroot option can do more harm than good. So basically nobody unrooted their Huawei m835?
I just tried to unroot my phone using speroneclick, and it ended up getting stuck at the Metro PCS Logo screen, and keept looping for seemingly forever, so I reset my phone :(
It's still rooted though. I'll try gingerbreak 1.2, now and post my results in a minute here.
I can confirm that using Gingerbreak's 1.2 APK works with unrooting, I tried it, then tested the Blizzard Battle.net Mobile Authenticator for a "rooted" message and said message didn't show up :)
Can you please go into detail on how you unrooted using Gingerbreak's 1.2APK. But I used Superoneclick to root my Huawei m835....would that be a issue if I do unroot using Gingerbreak 1.2 APK?
Thanks
I believe its 'unrootable' with the newest GB, I hear people are reporting its possible, have you tried going into GB and clicking the Attempt to UnRoot?
Why Unroot in the first place? o_O
I selling it and the buyer insists that the phone not be rooted. I rooted the phone using SuperOneClick but I not sure if its unrootable
Sorrey for the lapse within the times of my posting. life has been... chaotic. anyways, when I tried to unroot with SuperOneClick, I ended up having to facotry reset my phone, so I wouldn't recommend using it to root or unroot your phone. When I used GingerBreak and installed it on my phone, it did things very user friendly. there was a button to root and one to unroot, and both worked perfectly.
If you google "gingerbreak" you will see the first link is to the xda-developers website, and there is a download, but please make sure that you read all of the info before downloading gingerbreak, just as a forewarning.
Hope this helps!
Derek Elensar
Hope this helps!
Derek Elensar
Thanks for your reply Derek. I have already rooted my phone using SuperOneClick months back. Could I reroot the phone using gingerbreak since unrooting with SuperOneClick have dire consequences? I really need to unroot my Huawei m835.
Buyer insists that it not be rooted. Huh. If he wants a clean one that badly, then go get one from Metro. Having this phone unrooted is the dumbest thing I've heard. I would decline the sell, there's no stable root option as of yet.
Hope this helps!
Derek Elensar
GingerBreak bricked my friend's 'homegirl's phone and now is using a Huawei Pinnicale. Looks like it varies.
There's no surefire way since you used SuperOneClick, if it has an unrooting option, try that first. Using two Rooting apps can make permanent problems.
