The mystical update will eventually POP-UP as it is an OTA update. Once someone gets the zip file from the SD card before installing the update we can just apply it from the SD Card. As for now just wait and eventually it will come.
If it is saying Not Found it means you didn't copy the files from the ZIP into the main directory of the SD Card. On the main directory of the SD Card you should see the try3, system and unyaffs.Ooh alright thanks man!
And another thing. I was trying to install the firmware that BH_Man just did and when i open up my command prompt after i type adb shell and go to do the second line it says permission denied or it sometimes says its not found.
Any idea what this can be?
I just tried it again and now its telling me "not found" i dont understand why its giving me something different everytime.
Okay so did you unmount the SD Card from the PC and mount it to the phone. If you have the files on the SD Card root, make sure you unmount.
