This is what I did I have LG optimus m
1. Make sure USB debugging is enabled
2. Download USB driver and install on your computer
3. Download 3020 prl prl
4. Download and install qpst 2.7
qpst 2.7
5. Connect phone to computer
6. Open device manager expand ports and make note of what com port your USB device is on
7. Open up qpst configuration if com port is not shown select add port and enter com# (# being the one seen @ device manager)
8. Select service programming (phone must be selected to continue)
9. On the main menu setting tab click read from phone and will obtain phone info it will ask for ur spc
10. Spc code can be obtained through cdma workshop or by using checkesnfree.com Get Spc
11. Look for roam tab and there will be an option under preferred roaming to search for new prl locate it and select write it will ask for ur spc code again
note I'm not responsible for bricking ur phone I've done this before and familiar with the software even though this quick tut should be noob friendly
it may be possible for this method to work with ascend or indulge i have yet to try it since i only own an optimus
qpst 2.7
