I have Amon Ra's bootloader installed on my Nexus One, running a Cyanogen 2.1 rom.
I want to update my radio using this bootloader, but the radio image I downloaded has a .img suffix, and that bootloader only lets me install .zip files.
Should I just rename my *.img radio image to *.zip and then install it as usual?
I think the answer is probably "yes", but I want to double-check before I try this.
Thanks in advance.
PS: if the answer is indeed "yes", then does the renamed radio image have to be update.zip, or any it be anything-I-want.zip?
PPS: I am using MacOSX, and I haven't been able to find a fastboot executable for that OS.
Thanks in advance.
