Urgent help needed _/\_
I'm using the samsung galaxy grand and I need some help. yesterday an album from my gallery vanished, I.e it disappeared. ..it was way too precious for me to delete. i went to the file manager and in the search box I typed "." thinking that all files have a "." in them...I can find the pics there but scattered throughout my 16GB sd card. I need help to know hoe I can get the location of these files as I cant find them when searching manually
Try connecting ur device to your pc... If those are visible there in your pc... it will be easy to sort them....:)
Download mobogenie for android and connect your device to pc with usb debugging ON. then this software automatically detects your device and downloads the driver. when connected your device it will show each and every file in your sd card and the phones storage. Then download the file you want.
When am using internnet.and I was dowload ing mp3 songs.it showing "starting dowload" but its not display. And I check in media player , ther is no songs...give solution
Welcome pappuravi:)
Have you checked in your internal memory or your sd card via a file explorer?
Perhaps it is listed in .music or downloads?
