A
Android Question
Guest
Hi,
i have an Android galaxy s2 model GT-I9100
its been like 3 weeks now since i started facing problems with it , where i get like a block sign all sudden on the top bar instead of the WI-FI sign or the data connection then it shuts down and i cant restart it unless i keep it on charge.
and the second problem is when i use any application i downloaded it will work for few minutes then it shuts down ,even if the battery is full.
I need help what can i do?!
