Captain Sexy
I have my op3t in the way this will be my first and only USB c device. My question is will any of my old micro USBs work to charge the phone? I get it will not fast charge but can they work at all? Thank you
It probably does, but he has other spare cords that are micro usb.It should come with a charger and USB-C cable.
But a brand new USB-C cable costs less than the Micro->USB-C adapter itself?It probably does, but he has other spare cords that are micro usb.![]()
Hmm, not sure to be honest. Never researched itBut a brand new USB-C cable costs less than the Micro->USB-C adapter itself?
Yes, but you need an adapter with a 56k ohm pull-up resistor I believe, such as this:
https://www.amazon.com/gp/product/B018S827GU/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
I use a few of them
Edit: I trust the Tronsmart brand, but if you desire to go with an Anker brand, here is this:
https://www.amazon.com/dp/B01AHKYIRS/ref=psdc_3015402011_t1_B018S827GU
