USB C Cable
jshoe22
I'm having a very hard time finding a Galaxy S8 charge and sync cable. I want the OEM cable. All I can find is knockoffs that are made in China. I want to use fast charging and just prefer OEM. Any ideas where to get one?
Thanks
Thanks.... Any idea what the model is for the black cable. It seems as though you've had better luck with me on the site.
I'm typically one that likes OEM products, but with USB cables & chargers there is honestly no need. For cables, just stick with a reputable cable manufacturer (like Anker or Aukey), and for chargers sick with a reputable company (same as before) and get a model that lists Qualcom QuickCharge 2.0 or 3.0 support. They'll all give you full fast-charge support and they'll be every but as good as OEM and cost less. I've been using Anker chargers for years to great success.
Even better, I picked up a couple Choetech wireless chargers for about $14 each that even support fast wireless charging. Chargers and cables are pretty universal, as long as you avoid the suspiciously cheap ones.
