USB c storage question
Captain Sexy
I'm considering getting the op3, my major concern is the lack of SD card mostly for my music at the gym. I have about 60 gb I'd like to keep so I was thinking about putting it on a USB drive and just plugging it in when I need it. Will this work? I've never seen sombody do that but it seems logical?
A USB OTG should work. Not sure if this applies to you, but if you have an Amazon Prime acct., you can upload like 25,000 songs to their cloud for no addtl. charge. Beats keeping hard copies.
Thanks, I have everything in Google play music, but prefer not to stream to save data. That's why I prefer SD cards and looking for alternatives
OTG works perfectly, I picked up the fosmon USB-C adapter
(I'm in Canada but search the same or identical if in the U.S)
Works like a charm.
eftcfEJtGkA47Xvy6
