USB cable for Y9300
WLC
My USB cable for my Spreadtrum Y9300 has come apart and I am having trouble finding a replacement cable. The sleeve on the Micro B end seems to be longer than standard. Does anyone know where I can buy the cable I need?
Thanks!
Thanks!
Can you take a picture to get a better idea? It doesn't matter if its longer, as long as the connector slim enough to fit in. USB portion of the cable connector has to follow standard dimensions, but the plastic/rubber housing is "interpreted" by different vendors in their own way. Some will make it wider which doesn't fit case opening, etc. So you have to search around to find usb cable with a narrow housing to fit in.
  • Like
Reactions: WLC
