USB Case Keyboard Not Working
Pacobaba
Hello, my keyboard for Samsung Galaxy tab A worked perfectly, then some keys stopped working (like the whole N row ((caps,a,s,d..))) Then all of a sudden all of them stopped working, the tablet is still recognizable by the Sam A tablet and my other devices, but just doesn't type, I tried pressing caps lock to see if the lights on it would light up but they do not. The other thing is that the keyboard is integrated in the case so to look inside I would have to cut leather. Need help
Sounds like something has failed within the keyboard case itself, like the flexible and very thin printed circuit it uses possibly. Especially as some of the keys stopped, and now all of them? Given the sealed construction of it, I wouldn't have thought it was repairable. And so the whole thing needs replacing.
Oh well, thanks, I knew the keyboards circuit was thin to beggin with. Its a keyboard case afterall. It might not be the cable's fault cause it is recognizable, so I think you're probably correct
Rip keyboard
