USB configuration to MIDI
Hi all, Need helps please!
I need USB configuration to MIDI on my own S3 gt-i9300 but i have no option of this.(in USB computer connection, there is not choice MIDI except only MTP and PTP ).
Android version:4.3
Thanks in advanced
Thank you,
No, i have this cable usb midi.All connection between midi keyboard and s3 are ok but i think my little problem is just to choose MIDI option on my S3 USB preference.I don't see like this print-screen on parameter.What can i do to resolve of this please.
Thank you
Ahhhh.. Head over there to file transfer and you should be alright with the print-screen, you're welcome :)
Hi,
I need to update android system or what must i do for this MIDI will resolve?
Music ah, sorry I just looked up the term, well that is inside the USB settings as the pull down, head over to the system settings..
use the drop down and select file transfer.
