USB Hub for android
Sheyur
Hello, I want to know if is there some way to use an Wireless USB Hub to connect keyboard, mice, usb pendrive, external harddrive to the Android ?
as android phones dont work as usb hosts maby it is possible with Bluetooth/WiFi.
Thanks.
Do you mean that you wish to be able to access a network drive, like you can on computers? I remember my old Nokia N95 had a similar feature, hope there is such an app on android that facilitates connecting to shared folders over WLAN.
ES File Explorer for access to shared LAN files.
There are also Apps to LAN Bluetooth (Astro) also
Thanks.
in no way
Android phones can work as USB host. It just usually requires root and a custom kernel
I use it in my phone frequently. I hook my 32 GB flash drive up to my nexus 7 all the time because I store my music and movies on the flash drive in order to save space on the tab
