usb issues
vdoll
im using my s2 9.7 to fly a phantom 4 drone / my issue is it is very hard to connect after posting on phantom forum i was told to change to a differnt usb setting which i did works great however it keeps jumping back to the old setting , how do you save those settings it keeps going back to the mtd mode which does not work well with drone
thanks
Vince
