USB mode for Spotify
When I try to use sync the samsung galaxy player using spotify the player does not show up on spotify. I think the problem is I am not using the right USB mode. So do you know which usb mode to use?
I don't use spotify, but I am a little familiar with the USB setting thing because of recent troubleshooting I went through. My device has 3 USB modes to choose from. Go into "Settings" on your SGP, choose "Wireless and Network", choose "USB Settings" and you should have 3 choices: "Samsung Kies", "Media Player", and "Mass Storage". Hopefully your app (spotify) can instruct you which one to choose.
I know this doesn’t answer your question specifically, but if you didn’t know how to change the settings, this may help.
Spotify Music is protected by DRM so you can directly transfer the Spotify Music to USB Directly. In other words, you need to use some powerful and easy-to-use tool like TuneFab Spotify Music Converter for help in transferring Spotify to USB.
You do realize that this thread is 6 years old and the OP hasn't logged in since 2014?
