OK. My problem with the Galaxy S3 is that when I conect via USB to my PC, Winodws dont see the S3 like a mass storage drive, and in teh Galaxy S2 is possible this option.If you're talking about usb on the go feature I had no problem connecting to i747m with the same generic cable and usb stick as I did with my I9100 out of the box.
I have the GS3, very happy but the only thik is the USB Port. I cajnt enable mount disk like Galaxy S2, I know that if Root the phone I can do. But I dont want root that. There is any other option to enable USB port.
Thank
Thanks for you response
This is how I do it.
Download the drivers here Support - AT&T Cell Phones SGH-I747 | Samsung Cell Phones
Then go to your settings---> Developer options.
Turn them on and check the box for USB debugging.
Plug in the USB cable to the computer.
Install the drivers
Your phone will show up as a drive in my computer.
