USB OTG Storage
pwlcheng
Did you try your USB OTG adapter yet? You can play music directly from it using VLC player. I shall try to play movie from it later.
This screen capture is with my S6 Edge+, I'm sure it should work the same with Note 5, anyone care to try and confirm?
Works fine on my T-Mobile Note5.
I'm subscribed to some threads from the S6 Edge+,was thinking along the same lines as you:
A lot of commonality in the two phones,we can share info/experiences/trial & error/etc......
Looking forward to seeing ya' 'round both forums.:thumbsupdroid:
