JAy3001
Android Expert
So I'm having issues backing up a Kingston 32gb usb stick which is formatted in fat32.
This is my wife's work drive and contains over 4 thousand office files of small to medium sized files. 1 to 50mb max.
She reported to me she had issues getting a file off the stick last week, so I advised her to back it up. (IE me back it up)
The stick is used in a variety of Microsoft OS from win XP right up to win 10.
The issue I am having is that it will fail to copy the files over at either 3 or 4% on win 10 simply stopping on a file and getting no further, you cannot cancel to copy. But the PC is not hung and you can close the copy window, but the process is still stuck and you have to reboot to release the USB stick.
If I identify the file or folder at error and simply tell it to not copy those files when I try to copy again it will hang at 0% forcing another reboot. (Win 10 ##£@#!!)
Here is what I've tried:
- Standard repair from explorer, states there is a fault - after fixing it, then states there was no fault!
- Chkdsk states no issues
- USB drivers are up to date
- Tried all usb ports, same issue
- Tried win 7 pc, better control as when to file copy hangs after 1 minute you can skip the file - only this seems to then fail on every file one after another.
- I can copy files to the stick, read files directly and copy some files from the stick.
- Check the support area of Kingston Webby.
