usb tether
  • Start date Start date
A
Android Question
Guest
When I try to check the usb tethering , it gets unchecked by itself and says "mobile data unavailable or sim invalid" . Samsung s3
Welcome.
It is most likely that your carrier does not allow tethering. Many phones will enforce this automatically for their network. However, that particular error is telling you that there is a problem with your mobile data connectivity. Try a web browser on your phone and see if you can get to various websites.
If you can't reach websites, check to make sure you don't simply have mobile data turned off. If your battery ran low, it might have gotten automatically disabled and didn't get re-enabled once your battery was charged again.
Settings -> Wireless & Networks -> More... -> Mobile Networks -> Data enabled
Also look there for other settings that might affect it. If a setting isn't at fault and rebooting the phone doesn't help, you may need to contact your carrier.
If your carrier allows tethering but you still can't get it working once you're sure your mobile data is working, you might try PDANet, which is software made specifically to handle difficult tethering issues.
PdaNet+ -- Internet Sharing for Android
